cooling
dual 12 inch fans or a 16 inch single witch one is gonna keep me cooler?
i run one 16 inch fan on my car but i tried the dual first... used alot of juice and didnt seem to cool as well
What is the application ?
Intended use of said car ? |
well it gonna have a sbc with around 450 500 hp right now its a mild sbc with apx. 350 hp
street car it got a 160 tstat right now and when cruising its fine runs 160-190 depending on temp outside but with my flex fan and shroud at and idle it will climb to 220-230 and keep going if i don't shut her down its got a 3 core aluminum radiator looking to stay cool at idle thanks, logan |
Change that water pump to a Flow Kool. I've been having cooling issues for years with the stock pump in my race car, changed it out to a Flow Kool and ELIMINATED ALL cooling probs. :shock: :shock: :shock: :shock:
This is a "toe dance" . . You have to flow enough coolant through the radiator to cool it to 140° at the bottom or inlet hose on just about any gasoline engine being made today. The temperature going in at the top is a moot point, but the bottom is very important.
Dunno how big your fan is and how tight it fits in the shroud, but normally, unless you have an engine or a flow problem, a 15"-16" flex fan with about a half inch clearance at the fan tips to the shroud should cool it efficiently on both ends of the rpm spectrum. It sounds to me like your raditor isn't getting enough air to it at low speeds. Or, your radiator hasn't enough capacity. I say that because if it was too much flow at low rpm, you should have heating problems at much higher rpm, or all the time. Rule of thumb is; "The more coolant in the radiator and the longer it's in there, the cooler it is on re-entry to the engine" . . . |
hmm i think ill look into a flow kool water pump and prolly an elcetric fan
thanks guy! ,logan |
COOLING
LOGAN
I HAVE TRIED DIFFERENT PUMPS, FANS, THE ONLY THING THAT EVER HELPED WAS A BETTER RADIATOR, SEE U AT IOLA R C |
im sure im not the only that will say this.... but that "flex" fan has got to go... they are junk :wink:
yeah i dont like it either
| All times are GMT -8. The time now is 07:37 AM. |
