-   -   BBC spark plug gap help (https://www.racingjunk.com/forums/showthread.php?t=33700)
duby05 08-11-2013 07:23 AM
I am currently running .044 on NGK R44 or R45 have pro comp aluminum heads 10.5:1 comp. Accel high performance HEI distributor with accel 8.5mm plug wires. I was gapped at .050 and ran .6 slower than with current gap. Question is will I see better et with a smaller gap? Also looking to get a larger carb. Any opinions?
Swiley383 08-11-2013 07:55 AM
I ran my big block at0.35 it was 9.5 to1 with iron heads and a 850 carb
roadkill2 08-11-2013 10:16 AM
I'd say .040 but it has a lot to do with Compression ratios, Combustion Chamber configuration, and timing, as well as what fuel you're using . .
Just another one of those things that make each of our engines "a little different" . .
duby05 08-11-2013 10:54 AM
I'll gap my spare plugs at .040 and swap them out at the track to see what happens. I'm running 110 fuel only.
bjuice 08-12-2013 05:33 PM
Re: BBC spark plug gap help
Whaaat ? you have.6 slower...thats 6/10ths.. Ain't No way !!! .daym mine didn't slow down that much after breaking push rod wiping out cam lobe dropping a cylinder.....do you mean .006 ????? :shock:
duby05 08-12-2013 07:04 PM
Nope I meant .6...first pass ran a xx.61 something didn't feel right and only thing that had been changed was plug gap, pulled plugs re gapped and ran xx.01
Swiley383 08-13-2013 10:20 AM
I think you may have had a diffrent problem that was fix when you pulled the plugs like a bad connection/ connections on your plug wires. how much did your MPH drop off?
duby05 08-13-2013 06:23 PM
Only a few mph
bjuice 08-14-2013 06:06 AM
Only a few mph
a few MPH is a lot of ET....1/2 second or 2 mph in my Outlaw car is 3 car links easy... thats a Big Loss !
duby05 08-14-2013 10:43 AM
All is well right now. Going to see what a .040 gap does for me
