440 water pump housing
This engine being a 1978 has the bottom rad. Hose on the passenger side. I used the older housing so it would work with the radiator the guy bought. I see the blades on the pump are different also.would this make as difference since engine is a 78?
THAT is beyond my knowledge base.....Mark ?
Yes it will.
So I should put the housing that came on the 78 back on?
| All times are GMT -8. The time now is 06:53 AM. |
