-   -   Help needed (https://www.racingjunk.com/forums/showthread.php?t=33953)
holeshotta 11-02-2013 01:09 PM
Help needed
My dragster starting acting very strange today. Would turn on fuel pump (fuse issue) then tach is bouncing all over throughout rpm range from idle on. It's a 582 with msd 7al3 and 16 volt system. Car seems to run fine but I am concerned the ignition is shot. Any thoughts from the group. Thanks Todd
Swiley383 11-02-2013 04:50 PM
Check your grounds first that is always my first suspect I have seen them cause strange things.i would also check the tac
TheYellaBrick 11-02-2013 08:31 PM
Not only the grounding POINTS but also for a broken wire will 'make and break' with engine vibration.
gearhead1011 11-02-2013 09:23 PM
X2 on the grounds and don't count on the chassis for a ground. Run a wire from the battery to the MSD and one from the battery to the heads. You also should have a dedicated wire from the positive battery terminal to the MSD 12V. If it's not wired like that change it even if it has been like that since the car was built.
holeshotta 11-03-2013 05:57 AM
Thx all. Tearing all down and looking today
