Upping the boost on my 8-71 blown big block
Here's the set up. 468 BBC. 8-71 with 2 750's. Jetted square with 72's. 8 to 1 pistons. 61 top pulley, 54 bottom, for about 9% under-driven. Runs on 93 octane pump gas. Chassis dyno'd at 461 hp, 420 ftlb tq. I'd like to kick up the boost, without having to go to race gas. I figure swapping the pulleys would be way too much, even jetting up the carbs. So, what size top pulley can I go to? And how much higher on the jets?
Something is big time wrong, those dyno numbers are too low.
JMO |
I thought so too. It was on a portable chassis dyno at a car show, so who knows how accurate?
Do you have a boost gage? Is the blower teflon stripped?
You can probably get away with 1 to 1 ratio with 93 octane but i wouldn't think any more than that. JMO Zip. |
Thanks for the response!
Is there any "rule of thumb" as far as jetting increase, when changing pulleys from 54-61 (9% under) to 54-54 (1 to 1)? Like, maybe, one jet size per two teeth or something? Just some sort of starting point, so I don't melt pistons trying to find the right combo!
Re: Upping the boost on my 8-71 blown big block
Start with jetting that should put you rich and then lean it out to taste . . Kinda like making Chile . . . |
| All times are GMT -8. The time now is 04:39 AM. |
