slide-a-link
I have a 1978 Camaro. Does the spring pad bolt straight to the spring or on the stock rubber pad on a slide-a-link traction bar
I am running a slide a link on my nova I can't remember how it's bolted. I will try to look in the next couple days and let you know.
I have not had a chance to look yet been busy I will try this weekend.
I just looked mine are bolted with the rubber pad between the slide a link and the spring hope this helps you out. My car is a 74 nova so the springs should be similar.
| All times are GMT -8. The time now is 07:37 AM. |
