-   -   4000 stall? (https://www.racingjunk.com/forums/showthread.php?t=34263)
hotrod1994 02-09-2014 06:46 PM
4000 stall?
is 3800-4000 Stall too much on the street?
3700 lbs 500 hp sbc 4.88 gears
wrightway 02-12-2014 02:42 PM
Short answer no.
TheYellaBrick 02-12-2014 04:37 PM
Don't stab an taller gears in it though and do any highway cruisin. That high a stall and tall gears would not let the 'verter lock up and it'd burn it's self up in short order.(From a buddies personal experiences. Changed out 3 'verters before he had a light bulb moment , switched to a lower stall, problem fixed.)
Swiley383 02-12-2014 05:37 PM
I would run a very efficient cooler and maybe a trans temp gauge.
jtortorete 02-22-2014 05:29 PM
I would ask you, why would you want to? If your going out to do a street race that is one thing, but just to ride around making noise, not good on the wallet.
I sure would not do it.
JT
