-   -   need intake help (https://www.racingjunk.com/forums/showthread.php?t=34303)
toms131 02-23-2014 07:43 AM
need intake help
Is there anyway you can make sbc 23 deg.intake that cam off of a 9.325 block work on a 9.025 block?
excrewchief 03-24-2014 11:30 AM
make a set of spacers. as long as the ports are set up the same. kinda like thick gaskets not very hard
jmarksdragster 03-25-2014 09:47 AM
Going from a 9.325 block to a 9.025 block will require material be removed from the intake.
excrewchief 03-28-2014 09:46 AM
correct i sayed it backwards
promod45 08-30-2014 12:34 PM
I think dart sells spacers, you might want to call them, they make them for there dart rocket block
