-   -   wilwood residual valves (https://www.racingjunk.com/forums/showthread.php?t=34331)
etchison 03-04-2014 08:34 PM
i have a tube chassis door car with floor a mounted master. 4 wheel disc brakes and i have two blue 2# valves one front and one back. my partners new car he just picked up has the same breaking set up. but his car has a red(drum brake) one for his front discs? his pedal feels a lot firmer than mine. cars where both just had power bleeding done? is this something i dont know about running red valves to the front discs? thanks mike
hammertime 03-05-2014 11:45 AM
red is for drum (more pressure)
blue is for rotor style brakes
Dont want to mix the two.
markdunlap 03-05-2014 06:26 PM
wilwood
Blue = 2 # residual pressure.
Red = 10# residual pressure
etchison 03-06-2014 08:05 AM
after more looking i see that we have way diffrent brake pedal ratios. mine is closer to the piviot point
jtortorete 03-17-2014 04:34 PM
It also can be the master cylinder piston size. I smaller master cyl. piston can give better pedal feel. I went from 1 1/18" to a 1" master on my all wheel disc brake system, and the brake feel was much better, and the car stops better as well. That is because of the higher line pressure.
I do not use a residual valve. My master cylinder is wheel height. I do not want the drag, and I do not need to pump the pedal.
Jack
AndrewCharlson 08-29-2014 04:43 AM
Be sure to mount your reservoirs high if you have floor level master cylinders, then you will not need residual valves. This makes things very easy to bleed the brakes too as the air goes to the reservoir rather than the brake cylinder which would be higher if the reservoir is at floor level.
