-   -   Bbc valve adj with stud girdles (https://www.racingjunk.com/forums/showthread.php?t=34365)
ejm 03-19-2014 04:38 PM
Just bought a motor solid roller cam moroso says to adj valves before installing the girdles can I set them before and then install girdles?
mytmouz 03-19-2014 08:25 PM
Set them then check them again after you install the girdles. You will be surprised at how much they can change...
