-   -   Blower Question (https://www.racingjunk.com/forums/showthread.php?t=34380)
dak697 03-31-2014 10:19 AM
Blower Question
For a Drag Race only combination
In a SBC with an 11-1 initial compression, how much boost could you run?
1471 alcohol injected
coloradoguy 03-31-2014 01:00 PM
On our pro mod I used to work on, we were at about the same compression ratio, running about 45 lbs of boost...526" chevy, 11* big chief heads....kobelco superman 14/71..... had to put a ton of fuel in it though, even at 28* of timing, we had eight nozzles in the hat, and two in each port......ran good though!
