Electrical help needed
i have a bb chevy dragster and went to track today and fuel pump fuse is blowing after ignition is turned on. Car sat all winter an neveran issue before. I have a painless 6 switch panel with fuses. i am thinking a ground or a damaged wire. Its a real pain to pull apart so wanted smarter people than me to weigh in. thanks for any help you can lend.
fuel pump is locked up
ran fine the day before for 20 minutes idling getting ready, will check however, thanks!
Disconnect wire at pump and pull the fuse. With an ohm meter check contiguity to the chassis. if you get a reading the wire is grounded to the chassis.
Good luck, electrical problems..... |
Originally Posted by badfordfreak
(Post 269176)
| All times are GMT -8. The time now is 08:00 PM. |
