-   -   boost (https://www.racingjunk.com/forums/showthread.php?t=34397)
playtoys 04-07-2014 07:17 AM
boost
guess no one wants to give answer, wanted to know if you can hook up a boost gauage to the blow off value on 671 blower. thanks anyway.
mytmouz 04-07-2014 09:15 AM
I haven't ignored you, I just don't know the answer...
playtoys 04-07-2014 02:18 PM
Thank you I guess I'll try call a motor shop. Some guys on here are pretty smart thought one of them would know. But really thanks for the reply.
mytmouz 04-07-2014 09:22 PM
A lot of the gang is still missing after the board upgrade...
robertwendland 04-08-2014 05:58 AM
Why would you want to put a boost gauge on a blow off valve? Is't the most important thing to know is the amount of boost in the manifold? You can add a gauge right by the blow off and manifold to compare the two. What are you wanting to know?
playtoys 04-08-2014 01:46 PM
The blow off is on the manifold,it is a raised air gap manifold and I have no other place to find my boost,unless I drill in the manifold.
