LS1 compression vs boost
Hi guys, I'm currently building a 2003 LS1 engine.
I'm running ARP studded bottem end, standard crankshaft, SCAT forged H-Beam rods 6.100" I'm also going to be running a T04Z turbo with a front mount intercooler. The 38mm external Tial wastegate I purchased came with 2 pressure springs one at 9psi and the other at 14.4psi. Before I purchase pistons I have 2 questions, firstly what pistons should I be using forged or hyper with boost ? Secondly what compression ratio would you recommend I run for 9psi and or 14.4psi. I guess I need these questions answered before I purchase pistons so I can purchase a set which will lower my CR to what is required. I will be using 64cc heads also. Any advice would be helpful. Cheers Rick |
| All times are GMT -8. The time now is 02:53 AM. |
