-   GM LS engine talk (https://www.racingjunk.com/forums/forumdisplay.php?f=21)
-   -   LS1 Stock Fuel Pressure Regulator (https://www.racingjunk.com/forums/showthread.php?t=34405)
RickAbraham 04-12-2014 09:05 PM
Guys,
Another quick question.
With my fuel system on my LS1 I'm running 80lbs/hr injectors in a billit fuel rail with a 400lph Walbro intank fuel pump.
Is it ok to continue using the factory fuel pressure regulator and returnless fuel rail setup ?
Or would you recommend running a return line back into the fuel tank and run a rising rate fuel pressure regulator mounted in the engine bay ?
proserv 05-29-2014 07:21 PM
What kind of car is this in (make/model/year)?
hitclubgripe 07-25-2024 05:40 AM
The LS1 fuel pressure regulator is renowned for its reliable and effective fuel pressure adjustment capabilities. This component manages the fuel flow into the LS1 engine, ensuring stable operation and optimal performance in modern automotive applications.
