sbc 406 cam help
I have a sbc 406
12.5:1 Dart iron eagle 215 heads Dart single plain intake 850 holly I need a cam suggestion solid roller. Drag use only. Car weights 1840 with me in it. Thanks in advance. |
I will dig up my cam card tonight. I had a similar combo with higher weight. It was very consistent. ..
Thanks that will be helpful. How fast and heavy was your car?
I will have to try to dig it out tomorrow evening, I had to work late, and wife was already asleep, don't want to awaken her, lol...
10:40's on a motor, and 8:80's on a small shot in my avatar truck, 2,700 lbs with driver, and that was in the 1/4... |
Lunati grind, solid roller, Part #50172SB. 648 intake, .627 exhaust advertised duration is 301 int, 309 exh, 268 and 276 @ .050. 106 center line.
Thanks I'll look that cam up.
awag,
Do you have an altered? Well, anyway, whatever it is, at that light a weight you should go with a cam with a very long duration. |
| All times are GMT -8. The time now is 03:02 PM. |
