-   -   double ended screw-in wheel studs (https://www.racingjunk.com/forums/showthread.php?t=34414)
corvette59lt1 04-20-2014 09:48 AM
Does any body sell OR do I need to go to meachine shop to get Double ended screw-in wheel studs that is 5/8'-18 thread at one end and 1/2"-20 thread at the other end .,My axles take are screw-in 5/8-18 and my weld wheels are smaller lug holes ,1/2holes ( Lug holes to small ) to take the 5/8 studs ,double ended studs OR DRILL out wheel holes? ,Please help anybody had this problem ,Thanks
TheYellaBrick 04-21-2014 05:24 AM
Contact the axle manufacturer. I've not seen dbl sized studs before,not saying they aren't made, but you might have to have the wheel stud holes enlarged at a machine shop.
mytmouz 04-21-2014 06:00 PM
Either use 5/8 wheel nuts and a torque wrench or have the axles refilled for 1/
2...
bweighmaster 08-09-2014 10:11 AM
Die grinder dude !!
fla1976 08-09-2014 12:56 PM
http://www.bdcoldheadedproducts.com/...%2520X%25201/2
