-   -   Using a motor that has been sitting 8 years (https://www.racingjunk.com/forums/showthread.php?t=34425)
Swiley383 05-04-2014 08:39 AM
Since I blew my 383 sbc i am thinking about putting my old motor back in it been sitting for over 8 years. Do you thing this motor would be ok? The oil psi was good when I pulled it but it has not been turned in several years. If it's not stuck should I do anything other than the basic tune up and prime the oil pump? The motor is a mild 454 I will probably change the valve spring as well.
TheYellaBrick 05-04-2014 08:05 PM
What environment has it been in all this time ? Pull the plugs and see if there is any corrosion build up from moisture inside the heads/block. If so, count on the cyls being crusty ! Beg,borrow, or steal a bore scope and take a looksee into each hole. Drain the oil and see if and condensation comes out.
Swiley383 05-05-2014 10:07 AM
I did not think about the bore scope I will try to locate one.
Thanks
TheRabbit 05-05-2014 05:02 PM
Friend of mine bought a Ford Super Cobra Jet motor that had been sitting outside for about 20 years. Somebody stole the carb off it a long time ago and a tarp was put over the motor.
It fired up and ran fine.
No way is my luck that good, but you may be ok.
chevynovaman 05-14-2014 05:09 AM
The motor I have in my mud dragster sat 15 years, and run good when put back in. If
it was mine I would probly change valve springs from sitting.
