-   -   632 crate motor + EFI+ Procharger=HP? (https://www.racingjunk.com/forums/showthread.php?t=34458)
Pschlaht 06-09-2014 03:50 PM
So I am no PRO motor builder and I am looking at a Street/strip Motor that will also run on pump gas.
I see 632cid creat motors that claim 800+ HP on pump gas, and that in itself is a ton of HP.I have a Pro-street 67 camaro that LOOKS amazing and is almost complete and was thinking of tossing in one of these motors and adding holly's EFI and a pro-charger to the mix.
I have seen some crazy numbers with these compos and think it would be somewhat streetable.
So any thoughts on this?
Pros & Cons?
Thank you in advance
Swiley383 06-09-2014 05:28 PM
I would want to check the limits of the components in the motor. Rotating assembly and block would be my concern. You will probably be better off getting a motor configuration set up for a pro charger application.
