-   -   Looking for dragster set up help (https://www.racingjunk.com/forums/showthread.php?t=34557)
holeshotta 08-31-2014 01:43 PM
Have a 235 swing arm. 34.5 x 17x16 good years and 4:30 gear. Motor is a 588 on alcohol with glide. 5700 converter and starting line enhancer. Questions I have
Tire pressure
Launch rpm
Shift rpm
Have lost my way a but in the heat this summer , all opinions welcome
Thanks
shawnp 09-01-2014 11:51 AM
I would start at 5.5. You may end up around 5.25. Launch 4200-4600. Start at 7000 rpm on the shift. Without knowing much on cam and heads I would say that 7000 should be a safe starting point. I would ditch that converter and look for something in the 6400-6600 range. 5700 is a tight set up.
