-   -   Low oil pressure light and ignition cutoff safety switch (https://www.racingjunk.com/forums/showthread.php?t=34708)
RonHarris68 03-18-2015 06:40 PM
I am sure this has been brought up on here before, but need to ask one more time.. I would like to have a low oil pressure light as well as low oil pressure safety cutoff for ignition and was wondering if anyone has recommendation as to what switch and a diagram if possible of setup.
This is for drag race application.
Thanks in advance..
Ron
[email protected]
fla1976 03-19-2015 03:10 PM
Here are a couple links that should help. Save the diagram to "Paint brush" or similar program and resize it and print it out. The other link is for a 12 Lb switch. The momentary switch is for easier starting. I would leave out the oil pressure switch that follows the fuel pressure switch.
http://www.smileysracing.com/shoppin...i=60723&c=1730
https://encrypted-tbn2.gstatic.com/i...bCtPGqbyi1G5vs
RonHarris68 03-20-2015 12:01 PM
Thanks RacingJunkie for the reply... Is there a three connection type pressure switch on the market that will illuminate the idiot light with no or low pressure and an ignition cut out if falls around 15 PSI? Asking a lot but before I plumb in and wire two separate switches, just want to do some homework...
Thanks..
Ron
TheRabbit 03-24-2015 06:15 PM
http://www.summitracing.com/parts/mrg-7872/overview/
You could wire it to your ignition with a relay.
fla1976 03-29-2015 05:16 PM
^^^ Good setup.
