looking for info on SBC Pistons
A friend wants to build a SBC using a 6" rod and a 3.78 crank,Who makes a 13.1 piston for this? If he were using a 4" crank it would be no problem but its an oval track motor so hes limited on CI..
I am going to assume you mean 3.75" stroke. Howard sells one it is #HRC4584, made by Ross pistons.
http://kmjperformance.com/sbc-383-13...-hrc-4584.html |
Also, the 3.875" stroke SBC crank is also common.
| All times are GMT -8. The time now is 04:57 AM. |
