-   -   Mopar Mega block starter clearance issues (https://www.racingjunk.com/forums/showthread.php?t=34810)
indcontrols 06-05-2015 11:18 AM
I have a fresh 588 in the Dodge using a front & mid plate with an Ultrabell and a Glide. All is well so far except I am having starter clearance issues... The starter hits the block re-enforced area (I have 2 high torque starters, they both hit). I can install the shims that came with the JW Ultrabell, but then the starter is too far away. Any one else run into this issue?
Thanks,
John
