Not enough travel
IF,I think my drive shaft has been bottoming out in the transmission what would the part affected.I have the trans out to inspect/replace pump and thought this mightbe a good time to chech other stuff.Pan/ filter were clean,only abou ten passes after last change but the trouble I was having was it took a long time for gear to engage when first started car. Once it did it worked fine? It's a th400.
Originally Posted by cervidog
(Post 270853)
| All times are GMT -8. The time now is 07:02 PM. |
