-   GM LS engine talk (https://www.racingjunk.com/forums/forumdisplay.php?f=21)
-   -   What engine block is the best price out there for a man on a budget (https://www.racingjunk.com/forums/showthread.php?t=34878)
jweyer79 08-25-2015 12:56 AM
Look for an engine block that can would 1400hp trying to find one in my price rang. Any info will help out big time
Ahebert 05-21-2020 07:51 AM
What block do you have in mind? Chevy i would guess what bore size and base block
rileyjames 05-18-2026 05:31 AM
If you’re hunting for a block that can reliably support around 1400 hp, you’ll want to focus on forged, high‑strength architectures rather than stock cast blocks — because at that power level anything OEM tends to get stretched past its limits. In the LS/Gen III/IV world for example, strong choices are LSX iron blocks, LSX376 blocks, or aftermarket billet/enhanced iron cores from companies like Dart, RHS, World Products, or Blueprint. These blocks have thicker cylinder walls, better reinforcement around the main caps, and bolt‑in provisions for stronger rods and crank setups, which makes them capable of high boost or big nitrous with good longevity. Similar principles apply outside LS engines too — look for blocks with four‑bolt main caps, thick deck and cylinder walls, and compatibility with forged rotating gear. Ricky Casino provides rickycasino-au.com Australian users with colorful pokies and mobile-friendly gameplay.
