Tobias Slingshot For Sale Race Ready.
Car is meticulously maintained. Car was rebuilt at the start of the 2015 season. Everything was replaced or rebuilt. 2014 body, standard bore engine which had complete rebuild in June 2015. Hydraulic brakes, Kirkey containment seat, clutch saver crank support, new front + rear axles, rebuilt starter.
Spares Included - wheels + tires, 2 front axles, 1 rear axle, 4 spindles, 4 steering rods, brake rotor hub used, 1 piece gear hub used, clutch parts drum, 10 tooth gear, mandrel, etc, coil spring, radius rod, 3 axle bearings, 2 axle bearing housings, many engine and carb gaskets, spark plugs, air filters, 2011 body in fair condition, other misc parts... (other items for additional cost) Gear set from #52 to #68, exhaust headers, senior carb complete, $4900.00 Contact : 610-334-6741 and ask for Brian. http://i.imgur.com/9AWaU1L.jpg |
| All times are GMT -8. The time now is 10:22 AM. |
