Milky oil and alcohol
Old 07-28-2011, 07:25 AM
  #61
shawnp
Just out of curiousity, did you run the valves to check that they were set properly?
shawnp is offline
Old 07-28-2011, 10:47 AM
  #62
kod99
After running the three passes on gas, with the carb, the valve lash was adjusted hot.
0.024 on both the intake and exhaust, as per the cam card from Comp.
kod99 is offline
Old 08-01-2011, 07:34 PM
  #63
hammertime
Whats the cam specs besides lift ? and where did the actually install it at ?
For it to have that much crank case pressure you'd have to have slim to no vacuum. They are is major issues there, and a good amount of power there also.
hammertime is offline
Old 08-12-2011, 07:41 AM
  #64
kod99
If I could figure out how to insert a pdf file in my post, I could post the blueprinting specs and dyno runs.
kod99 is offline
Old 08-12-2011, 07:08 PM
  #65
hammertime
photobucket.com
Old 08-13-2011, 06:13 AM
  #66
kod99
photobucket.com
Here goes:
kod99 is offline
Old 08-13-2011, 07:14 AM
  #67
kod99
Another interesting fact is that, on the first three dyno pulls on race gas, the crankcase btween 8 and 10 inches of vacuum.
It was only when I switched to alcohol that I started to build crankcase pressure. At times, as much as 29 psi.
kod99 is offline
Old 08-13-2011, 09:04 AM
  #68
hammertime
Says its not there, did u delete it ?
I assume you havent raced it yet ?
Old 08-13-2011, 09:14 AM
  #69
kod99
Sorry. I messed up and deleted it.
First runs on the new engine tomorrow.
Here it is again:
kod99 is offline
Old 08-13-2011, 09:25 AM
  #70
kod99
Here is a link to the dyno pulls:
The manifold pressure is actually the crankcase pressure.
The file name indicates the run number. The forst three runs were on gas, the remainder on alcohol.
http://s205.photobucket.com/albums/b...Dyno%20Sheets/
kod99 is offline
