cooling ?
Old 09-30-2007, 02:45 PM
woodsman
Originally Posted by zipper06
Definately do something in the thermostat housing such as restricting the flow. I use a restrictor washer with a 3/8" hole to slow down the water flow, giving it more time to cool in the radiator, when i run gas. but most of the time i run alcohol where i have no cooling problem.
Zip can you confirm that 3/8" was a typo if so I am going to get the little moroso kit that comes with 5/8",3/4" an 1" and use the 5/8" in mine because at the moment I don't have anything in it now.
woodsman is offline
Old 09-30-2007, 05:21 PM
etbird
Well at 35 the timing sounds right on, so I will have to agree with some of the others about air flow or water going thru to fast.
etbird is offline
Old 10-01-2007, 10:25 AM
Timmyboy86
CRAFTSMAN
I’ve been wondering about those electric pumps some guy told me they won't work on the street.
p.s. same person said one lip on the exhaust port kills 25 hp, you need heavy parts to make an engine run on the street, .027 ring gap is worn out "equivalent to 100,000 mile engine" you need .005, stainless rockers are just to heavy you need aluminum "Harland sharps the greatest there is", you can't run a 6 inch rod in a 400 Chevy on the street it won't last past 10,000 miles, main girdles are useless they do nothing, you can't make an 850 cfm carb run with a 750 or a 900, tunnel ram is the only way to go regardless of cubic inch, the one that makes me laugh the most is a .060 over 454 with stock 396 heads flat tops and a cam of 3500-6500 makes 650hp+ will run high 10's easily
Timmyboy86 is offline
Old 10-07-2007, 08:53 PM
davebat
JUNIOR BUILDER
Why does a 6" rod in a 400 make it wear out so quickly?
davebat is offline
Old 10-07-2007, 08:58 PM
Oop!! sorry 5/8" washer.
Old 10-07-2007, 10:54 PM
woodsman
Thanks Zip thats what I am going to go with 5/8".
woodsman is offline
