ANY MOPAR GUYS HELP IM A GM GUY BULDING A MOPAR I GOT ??
Old 11-25-2008, 10:35 AM
mopar1962
JUNIOR BUILDER
68... love the area your in almost bought 189 acres right outside clinch mountain reserve a few years back, wish I had. luv the area.take care
mopar1962 is offline
Old 11-27-2008, 04:23 AM
footbrake
Default switch
If you go to moparts.com, it will tell you everything you need for your application to make the switch
footbrake is offline
Old 11-27-2008, 05:47 PM
mopar1962
JUNIOR BUILDER
on the 440 use a 1969 to 1974 block, these have the higher alloy content and have an extra strengthing rib running down the side. try to find a good block with .525 thick main webbing around the shell. most 440s have .375 . hope this helps.
Old 12-22-2008, 09:22 AM
morrell
Default Re: switch
Also try Bigblockdart.com lots of mopar nuts! 8)
morrell is offline
Old 01-02-2009, 06:21 PM
mopar1968
mopar1968's Avatar
i have a set of 915 out of machine shop.
mopar1968 is offline
Old 01-17-2009, 01:13 PM
mopar1962
JUNIOR BUILDER
big block mounts is all ya need to get it in there going from a 318
Old 01-21-2009, 01:18 PM
TheYellaBrick
TheYellaBrick's Avatar
Mopar engine swap mounts;
http://engine-swaps.com/
TheYellaBrick is offline
Old 01-21-2009, 06:36 PM
  #18
mopar1968
mopar1968's Avatar
You don't need any kind of swap mounts, thats money wasted, take the mounts off of the 318 and they will bolt right up to the big block, both big block and small block have the same bosses on the block, put the engine right in, get b-body headers and go driving. My brother has a 64 plymouth savoy, had a wide block 318 we installed a 426 hemi, right back in the same location, same k-frame as your car.
Old 01-21-2009, 06:48 PM
  #19
TheYellaBrick
In '71 after I got home from the Army, we stuffed a 440 Mag into my '64 Belvedere that had the old poly head 318. I can't remember exactly what we did for mounts though......With 2.73 rear screws she would get waaaaay up there over 135 ! And on bias ply tires....I have NO idea why I am still alive....... :shock: :shock: :shock: :shock: :shock: :shock:
