overheating hauler
Old 03-08-2009, 07:20 PM
gearhead1011
gearhead1011's Avatar
More than likely it's the radiator. Like the others have mentioned it can be partially clogged and have the same effect as a radiator that's too small. Head gasket is unlikely. The 7.3 that was used in 2000 had almost no problems with head gaskets and if that was the problem it wouldn't cool back down by dropping your speed. If you have a temp. gun you can try checking the temp. of the radiator after it has been warmed up then shut down. If the lower part of the radiator is a lot cooler then the upper part it's a good indication that the radiator is clogged.
gearhead1011 is offline
Old 03-09-2009, 03:48 PM
blowenstang
APPRENTICE
yep you guys are right it was the radiator took to a shop an they said it was fuck thanks for the help
blowenstang is offline
Old 03-09-2009, 06:40 PM
TheYellaBrick
TheYellaBrick's Avatar
"When in doubt, just ask the friendly folks on the RACING JUNK FORUM !!"
I see a You Tube commercial here.......
TheYellaBrick is offline
Old 03-09-2009, 10:17 PM
cepx111
OMG my virgin eyes!
cepx111 is offline
