Aviation Fuel in a high comp engine
Old 07-12-2009, 07:34 AM
itsabird
i ran it back in the day so to speak, had no prob, always blended it with leaded fuel.
itsabird is offline
Old 07-12-2009, 07:45 AM
fla1976
fla1976's Avatar
Default AvGas
David, is this the info you were looking for?
Couple more takes on it.
http://www.waterfordhills.com/results/aviation.pdf
http://www.thumpertalk.com/forum/arc.../t-311517.html
fla1976 is offline
Old 07-12-2009, 09:30 AM
wvhippie
Guys thanks for all the info. As always it has been a big help.
wvhippie is offline
Old 07-12-2009, 09:32 AM
kwkracing
All i got from that article was they want you to buy expensive gas so they tell you how bad av gas could be.
kwkracing is offline
Old 07-12-2009, 11:27 AM
fla1976
fla1976's Avatar
Default AvGas
I posted different views so everyone can read for themselves and decide what they want. I have run it and never had a problem. But, no matter what the subject, there is always another opinion. I never burned a valve or piston so I would run it again. I might've run better on race gas and been more consistent. The same goes with running alcohol. There are people that say it is hard on parts, but if you prepare the car for it's use you will probably be fine. When you take short cuts and don't think it through properly is when things go bad. JMO
fla1976 is offline
Old 07-31-2009, 03:28 AM
mopar1962
JUNIOR BUILDER
pushing it at 12.5 to 1, if ya get caught somehow its a $25000 fine
mopar1962 is offline
Old 07-31-2009, 09:32 AM
desoto30
JUNIOR BUILDER
Originally Posted by Tod74
What is the difference between AV GAS and "CAR GAS"?
one of several/many differences is that av gas has an anti icing agent added to the fuel.
desoto30 is offline
