468 bbc lay over
Old 07-13-2009, 06:42 PM
hammertime
Should just remove it, no need to have it there. Do you run a crank trigger ?
hammertime is offline
Old 07-13-2009, 06:50 PM
wildchild71
APPRENTICE
no i don't run a crank trigger
wildchild71 is offline
Old 07-14-2009, 01:43 PM
LuckyDawgRacing
CRAFTSMAN
The leakdown was performed at Rons? did you take the car or engine there?What pill is in it?
LuckyDawgRacing is offline
Old 07-14-2009, 02:08 PM
wildchild71
APPRENTICE
i've tired from the smallest pill to the largest pill nothing changes ...
Old 07-14-2009, 02:41 PM
You're running a front mounted tank,(right), also is the line feeding the pump at least a #10, also is the pump mounted below or level with the bottom of the tank. I had a friend who had the pump mounted too high, and on one run he forgot to refil the tank between rounds, luckly the other guy redlite, and my friend ran 4 ths slow, pulled plugs checked everything, not popping or anything. Then he slapped himself in the head, filled the tank and went right nack to the previous #'s. He's since remounted the pump below the bottom of the tank.
Just a thought
Old 07-14-2009, 03:22 PM
wildchild71
APPRENTICE
lol yeah i have seen that before ...but i have the #10 and i have the pump low ...i have a toilet on my other car also ..it runs and wins great leading the 7.0 points right now...but this other car is well i have no idea any more
Old 07-14-2009, 08:18 PM
O'K partner, i was just checking, very well could be MSD problem, i had a new 2 step that was bad once , and the car sat on the line and jumped up and down on the trans brake without breaking the beams, i have a vid of it but i'm too embassased to post it, took 3 trips to the track before i figured it out. I'm the opitidy of stupidity, and now i have a spare of everything, but i might not be able to figure it out in time to race the same nite. O'h by the way do run a 4.1 toilet bowl so i am familar with them.
Old 07-16-2009, 05:29 PM
  #18
wildchild71
APPRENTICE
im thinking it's in the tranny now ....going to swat the msd first ....has anyone ever had a tranny hold it back like your pulling a sled down the track?
Old 07-16-2009, 06:30 PM
  #19
suicidebomb
I had a transbrake switch short out intermittatly, turning the tranny brake on and off going down track, felt just like I was dragging somthing. VERY hard on powerglides.
suicidebomb is offline
Old 07-16-2009, 07:29 PM
  #20
wildchild71
APPRENTICE
was it doing something in high gear? i know low gear it will lock up the tires..i have forgot to put my car in low after the burn out and hit the transbrake just to fly out of the lights ...that suck lol ...thanks for the info im going to check it tomorrow ...im putting on a race here ...my first one out of my pocket just hoping people show "BEST OF THE BEST " race
