cooling 400 cu in SBC
Old 09-20-2009, 10:44 AM
OneBadGMC
Yeah, they put water into the heads between the center two cylinders. Reason being is those two run so darn hot on a SBC...
It helps prevent detonation on those cylinders. It's common practice on roundy round stuff.
Doesn't really do too much though for over all cooling.
OneBadGMC is offline
Old 09-20-2009, 06:20 PM
chevyart
Default cooling 400 sbc
thanks guys i will just use the best of everything (rads, fans, water pumps etc and just have faith in all this good equiptment to do a good jobkeeping me cool thanks again guys for all your input chevy art PS what should i do for a radiator cap. i am using a good ron davis aluminum radiator 26x19 2 inches thick, mechanical fan with an aluminum shroud, good miledon water pump and HP thermostat, but i dont understand anything about radiator caps and usage of an overflow bottle. any suggestions would be appreciated about this chevy art
chevyart is offline
Old 09-21-2009, 02:01 AM
JEFF69Z28
MAKE SURE YOUR HEADS HAVE THE STEAM HOLES DRILLED IN THEM.
JEFF69Z28 is offline
