Help Needed~ Which Heads should I use
Old 10-09-2009, 07:49 AM
sshannon024
Ok, I had been on the fence about the cam and wanted to use the best one. I also wanted to listen to the guys building it, but I myself had always leaned towards the Lunati vodoo cam. So I will let him know today to send the other back and get the vodoo. I will be running at least a 3000 converter, and prob a 4.56 geared rear end.
sshannon024 is offline
Old 10-09-2009, 09:56 AM
bbchevy
Default Heads?
If You decide to go with the IRON Eagles?Make sure they are the PLATINUM Series and NOT the Org.Iron Eagle Head.I went through that,and 1st design Heads were JUNK as far as Flow,thats why I ended up with a Set of KILLER World Sportsman II's.
Later
G 8)
bbchevy is offline
