More power needed from my ZZ4 Fastburn
Old 11-12-2009, 03:27 PM
DirkaDirka
DirkaDirka's Avatar
Hey Monte he is at 7000 at the 1/4 mi mark
DirkaDirka is offline
Old 11-12-2009, 03:33 PM
FullTimeRacing
Originally Posted by signsbyesa
what does "zz" & "4" stand for? :shock:
ZZ4 is a crate motor from GM
FullTimeRacing is offline
Old 11-12-2009, 03:34 PM
FullTimeRacing
I missed that part,thanks
Old 11-12-2009, 03:42 PM
FullTimeRacing
Aktroop,post the times on the slip.
60" 330" 660" 1000" 1/4 mile
with a 4.10 gear you will be in the power curve in steed of over reving.
6500 should me max RPM
Old 11-12-2009, 03:45 PM
TheYellaBrick
TheYellaBrick's Avatar
Do you have a posi in it now, or are you one legging it ?
ANY major gain of HP will be in the heads and supporting staff.
Minor, low dollar gains are going to be many small things working together.
TheYellaBrick is offline
Old 11-12-2009, 03:54 PM
aktroop
Yeah I think your right. I guess I should worry about hooking up the power I have instead of making more powere right.
aktroop is offline
Old 11-12-2009, 03:59 PM
DirkaDirka
DirkaDirka's Avatar
Not saying to not get more power out of the motor.
You can do small upgrades to the motor as well as the suspension if the money allows it.
Old 11-12-2009, 04:03 PM
  #18
aktroop
We run 1/4 mile
I have 4:88 with mini spool
9" slicks
4500 stall
350 auto trans
Hey guys, thanks for all the help!! Keep it coming. I just got off the phone with a friend of mine who suggested checking the pinion angle and shaving the heads. What do you guys think?
aktroop is offline
Old 11-12-2009, 04:08 PM
  #19
DirkaDirka
DirkaDirka's Avatar
I think that shaving the heads will get a lil more compression out of it. I dont know what the pinion angle would have to do with it.
See the rear springs actually twist or flex when you launch. That right there actaully changes the angle on the rearend. The harder you hit the stock rear springs run the risk of actually bending the spring or breaking a mount to the spring , or even breaking the spring too depending on how old they are.
Old 11-12-2009, 04:09 PM
  #20
aktroop
We run 1/4 mile
My RPM is consitantly 7,000 at the line
4500 stall
350 auto trans
4:88 gear with mini spool
I just got off the phone with my friend who suggested shaving the heads and checking the pinion angle. He said the pinion angle may be causing it to spin so much off the line.
Thanks,
aktroop
aktroop is offline
