OIL PSI AT END OF 1/4 MILE
Old 11-03-2010, 06:45 AM
TheRabbit
TheRabbit's Avatar
Originally Posted by JEFF69Z28
Originally Posted by blowninjected540
What oil filter are you running ?
fram racing filter cant remember the number.
OH NO, not a Fram.
Change to a different filter and see if that helps. I use Wix and will NEVER put a Fram on anything I own.
TheRabbit is offline
Old 11-03-2010, 06:48 AM
blowninjected540
OH NO, not a Fram.
Get rid of the fram filter !!!!! Use a Wix racing filter.
blowninjected540 is offline
Old 11-03-2010, 07:44 AM
Tod74
I 100% without a doubt would have that engine out of the car and the pan off to inspect the bearings. no way would I just hope for the best. If you don't you will worry yourself sick every time you here a little noise from it,or at least I would.
Tod74 is offline
Old 11-03-2010, 08:17 AM
JEFF69Z28
NO DOUBT ABOUT IT,THE PAN IS COMING OFF TO SEE OF THE PICKUP CAME OFF.HOPEFULLY I CAN DO THIS WITHOUT PULLING THE MOTOR.TOD YOU THINK THERE IS BOTTOM END DAMAGE WITH THE OIL PSI THAT LOW AT 7100 RPM?
JEFF69Z28 is offline
Old 11-03-2010, 08:56 AM
TheRabbit
TheRabbit's Avatar
It's not worth taking the chance. If it were me I'd pull it and go through it and put a Wix back on it.
Old 11-03-2010, 11:28 AM
MEMRACING62
OH NO, not a Fram.
THE ORANGE CANISTER OF ENGINE DEATH!
MEMRACING62 is offline
Old 11-03-2010, 12:51 PM
Tod74
Have any of you had any first hand experience with a failure due to a fram filter,or are these comments based only on the bad reputation they have?
Tod74 is offline
Old 11-03-2010, 12:54 PM
  #18
Tod74
maybe maybe not. Spend at most a couple hundred bucks now checking/replacing the bearings or worry about it tossing a rod out the side of the block if a bearing is damaged and spins later.
Peace of mind is worth something.
jmo I have been called "Paranoid Floyd" before so .....
Tod74 is offline
Old 11-03-2010, 01:03 PM
  #19
blowninjected540
I have been there with the fram filters. And I caught it early. Still I pulled the pan and check bearing and put a new oil pump and cleaned everything. Fram Sucks I wouldn't run them on my lawn mower.
Old 11-03-2010, 01:25 PM
  #20
MEMRACING62
experience.. yup. 2006 chevy trailblazer STOCK. almost took out if it wern't for warning system.
