rpm not changing
Old 01-20-2011, 05:00 AM
hammertime
Originally Posted by smokinsmallblock
yes 1 have a 7200 chip in it. its a 434 dart pro 1 heads it runs 590's all day, have a 670 645 cam in it. shift it at 6700rpm. 6000 coverter. car weight is 2450 wit a power glide
. What is your stall that you checked, at the launch, after the shift fallback and if you've checked in the garage what is it ?
What high side chip do you run ?
hammertime is offline
Old 01-20-2011, 05:03 AM
TopspeedLowet
6000 converter, is this something you checked or thats what they told you it would be ?
If you changed the gear and seen no change, it all leads to the converter. What is your stall that you checked, at the launch, after the shift fallback and if you've checked in the garage what is it ?
How in the heck can a loose or tight converter possibly limit the top rpm?
The speed is diminishing with gear changes and the rpm the same?
Bruce
TopspeedLowet is offline
Old 01-20-2011, 08:00 AM
smokinsmallblock
APPRENTICE
yes it can go past 6700rpm in first gear. i shift around that area, steve said i need to shift around 7000rpm but it slows up. if i take my trans break chip out and go on the converter it goes to 5900rpm. my shift lite comes on bout half track wit the 3 gears. heres my number mabe i can explain a little better 5404551035
smokinsmallblock is offline
Old 01-20-2011, 06:16 PM
fast75vega
could you be running out of fuel on the top end..... which could be limiting your rpm........ :wink: thats alot of gear changes for it not to change ur rpm though the traps
fast75vega is offline
Old 01-20-2011, 06:27 PM
hammertime
Bruce
Simple, If your already driving through the converter you wont see any rpm change with a gear change.
Old 01-21-2011, 03:15 AM
TopspeedLowet
Default There is a Wood chuck in the wood pile here
If he were driving thru the converter with a given gear, then his MPH would not have diminished with higher numerical ratios and his rpm would have to increase at the finish line and through out the pass,.......... unless the car was not moving and you were doing a stall test.
I got a feeling that we do not have all the information we need to accurately diagnose this persons car set up problems or problem.
I would suggest that this guy talk this over with Steve Schmidt further and see if something else in the engine combination is relenting or unhappy with the new port job?
Best of luck solving you issue
Bruce
Old 01-21-2011, 05:23 AM
itsabird
Just out of curiosity, what size tire or you running?
itsabird is offline
Old 01-21-2011, 03:50 PM
  #18
smokinsmallblock
APPRENTICE
tire size is 14 32. ok let me ask yall this question. i ran 5.92 at 6700rpm wit the 514 in the 1/8th, in the 1/4 mile i ran a 9.54 at about 7300rpm. do that add up?
Old 01-21-2011, 04:36 PM
  #19
maxpower671
SENIOR BUILDER
NO. you should be at least .20 seconds quicker...???
maxpower671 is offline
Old 01-21-2011, 04:52 PM
  #20
itsabird
I am starting to think along the same line as fastvega, fuel problem, a little lean, did you retune your carb after the port work, and what was the 1/4 mph on that pass?
itsabird is offline
