whats the best motor combo to run 10.50
Old 02-02-2011, 06:24 PM
billyd21970
what does it help to have a 4/7 swap on the cam?
billyd21970 is offline
Old 02-02-2011, 06:26 PM
fast75vega
it helps the motor breath better and free's up some ponies....... about 30 of them on average :wink:
fast75vega is offline
Old 02-03-2011, 02:30 AM
JEFF69Z28
i think the 4/7 swap has something to do with helping harmonic vibration
JEFF69Z28 is offline
Old 02-03-2011, 02:31 AM
JEFF69Z28
what head are you running and whats the compres.
afr 210 race ported,11.1 compression.
Old 02-03-2011, 03:08 AM
fast75vega
it allows the exhaust to flow better and moves the hot spot as well.... which frees up horse power
here is a good 5 page write up in hot rod as they explained it all and tested it...... very good read
http://www.hotrod.com/techfaq/113_07...ams/index.html
Old 02-03-2011, 06:45 AM
JEFF69Z28
No way your getting 30 hp more by changeing the firing order,5-10 if your lucky.
Old 02-03-2011, 07:17 AM
fast75vega
the one show on speed tv(cant remember which it was) their was on a $3500 crate edelbrock motor.... they dyno'd it right out of the crate and then swapped just the cam for the 4/7 and it made 30 more horse and more torqe...... with the same carb and intake
Old 02-03-2011, 07:35 AM
  #18
fast75vega
actually it was on horse power tv..... they used a edelbrock $3500 crate motor.
Old 02-03-2011, 08:27 AM
  #19
curtisreed
curtisreed's Avatar
You will get different results on different motors. Stating a 30hp increase is a large blanket statement. Some may others will not.
Curtis
curtisreed is offline
Old 02-03-2011, 09:06 AM
  #20
JEFF69Z28
those tv guy's want to be engine guru's, it's like the wwf kinda fun to watch but almost impossible to believe.
