BBC what do you guy thank it will make
Old 03-06-2011, 09:03 AM
curtisreed
curtisreed's Avatar
I say 673hp
curtisreed is offline
Old 03-06-2011, 04:13 PM
itsabird
If you will, post the results. i used almost that same combo to tune my chassis, i used a set of 820 ovals with a back yard port job and 2.25 -188 valves, no idea on the number of ponies, but the thing ran dang good.
itsabird is offline
Old 03-09-2011, 07:00 PM
bixblk
bixblk's Avatar
Default guess
compression helps, but the heads will hurt this combo 689 HP to 700 and 600 to 625 foot lbs
Let us know good luck , it should be a good stout durable motor
bixblk is offline
Old 03-10-2011, 04:53 AM
hammertime
Default Re: BBC what do you guy thank it will make
Originally Posted by wibberg350
Its a 461 13.8to1 scat rods and crank srp pistons Gm 990s ported 2.30 in take 1.88 ex comp cam .714 in .680 ex 278 in 282 ex at 50 intake is a ported super vic 1050 domanator on e85 2in into 31/2 headers what do you guys thank
720 peak hp and 675 avg
hammertime is offline
Old 03-10-2011, 02:18 PM
wibberg350
APPRENTICE
not sure what head i should have used the motor is in a mud drag truck and they have a stock head casting number rule and it has to be a steel head from what i have read the gm squair port heads were the best. i didnt have them flowed but i did cc the and the intake ports are right at 345 let me know what you thank i can do to get alittle bit more out of her im wanting 750
wibberg350 is offline
Old 03-10-2011, 03:39 PM
TheRabbit
TheRabbit's Avatar
I'm looking at my dyno sheet from my old 548. It made 793 at 6,700. It was similar to your build, but I did have a set of aluminum heads c&c 'd by RFD. They flowed 400cfm at .800 and I did have a vacuum pump.
I doubt with those heads you're gonna get into the 700's, but I'm not fimilar with them. Even though you have to run iron heads can you run a vacuum pump and a dry sump? Not cheap hp, but you gotta do what you gotta do to win!
TheRabbit is offline
Old 03-10-2011, 04:04 PM
wibberg350
APPRENTICE
no vac pump and must have a wet sump
Old 03-10-2011, 04:47 PM
  #18
itsabird
That head may get you close, one of my worries would be the big valve size, 4.280 bore may be a little small for that size valve.
itsabird is offline
Old 03-13-2011, 11:14 AM
  #19
tcarda
I think you will be around 670-680 hp and 570-590 tq, but I think the ported Super Vic is going to hurt you. Thats a big intake for your cu in. A Victor Jr. would be a better choice...IMO.
tcarda is offline
