Quick question
Old 05-13-2011, 07:32 PM
dragonmaster093
well ya could put mild 350 in her and set the rebuilt nm motor off to the side
dragonmaster093 is offline
Old 05-14-2011, 07:08 AM
mopar1968
mopar1968's Avatar
You have a leaking head gasket :!: Water pump won't push back into the overflow :!: :!:
Mark
mopar1968 is offline
Old 05-14-2011, 10:04 AM
wazup
I agree with Zipper, or i have seen a partly cogged raditor do the same. The water cant flow freely builds up back pressure and pushes back into the over flow bottle and can happen with week rad cap too. JMO
wazup is offline
Old 05-16-2011, 12:58 PM
Scooterz
As always, thanks gentlemen.
Decided to install the new front springs/shocks & do some light front-end work & then pull the motor in about a week when that is done. Got an engine stand, got a engine hoist lined up, buying new heads soon too. Going to stay w/ the 327 block, but get better aluminum heads. So far I think I will keep it pretty mild & not get too carried away. What do you think about a 250ish/480ish cam w/ my 4 speed??? With 202/160 heads, but use same crank & new bearings, soft gear drive, rings, oil pump, etc.... you think that cam is too big for a street car?
Scooterz is offline
Old 05-28-2011, 05:23 PM
Harbone
Moderator
Harbone's Avatar
not all all, I have a 492 lift cam in my Camaro, with the 4 speed you dont have to worry about it loading up in gear at idle like an automatic, I am idling easy at about 850-900 rpm all day long.
Chris
Harbone is offline
