Maximum bore BBchevy
Old 01-04-2012, 05:40 PM
cncmotorsports
Dart or world block only for the 4.500 bore
cncmotorsports is offline
Old 01-04-2012, 06:28 PM
TheRabbit
TheRabbit's Avatar
I agree that a dart block is the way to go. I used a 502 gm block with a 4.25 stroke and 4.530 bore to make a 548. It was 868hp and the block help up fine.
TheRabbit is offline
Old 01-05-2012, 07:13 AM
TS1955
Originally Posted by hink
Originally Posted by ewing
For a 4.500" bore, it's time for a Dart or World block.
Dart only !!!!
I'm working on a Dart Big M now with a cracked oil galley. It's leaking oil into the coolant passage.
TS1955
TS1955 is offline
Old 01-09-2012, 09:58 AM
oldandtired
oldandtired's Avatar
Originally Posted by coloradoracerguy
I wouldn't try the 4.5 stroke either, as you'll likely hit the oil gallery in the oil pan rail while trying to clearance it..........
x 2
JMO - Max reccomended on truck block is 4.25 with steel rods at 2.10 journal (SBC size).
oldandtired is offline
