Hurt my motor today
Old 04-09-2014, 08:25 AM
TheRabbit
TheRabbit's Avatar
That sucks. Hope it's not to bad. I'm still waiting to get mine back after it dropped a valve last year.
TheRabbit is offline
Old 04-18-2014, 09:27 PM
Swiley383
Swiley383's Avatar
Finally got a chance to pull the oil pan off my motor NOT GOOD. The oil pump pick up broke off about an inch from the pump how it had any oil pressure I have no idea. Lots of. Bearing material in the pan I haven't pulled a cap yet but by the stuff in the pan I would say the crank will need turning. The fact that it did not put a rod thru the block amazes me.
Swiley383 is offline
Old 04-18-2014, 09:30 PM
Swiley383
Swiley383's Avatar
Here is a picture of what the pan looked like
File Type: jpg
Old 04-19-2014, 09:08 PM
mytmouz
mytmouz's Avatar
Unfortunately, I have seen a good many of those 'bolt on' pickups do that. I tack mine in place like the old days, even when I use them as a result...
mytmouz is offline
Old 04-20-2014, 07:01 AM
Swiley383
Swiley383's Avatar
I always have tacked them on but this was the first bolt on pick up I have used. The instructions said not to but I will from now on.
Old 04-25-2014, 12:40 PM
Swiley383
Swiley383's Avatar
Here is a picture of the #1 rod bearing and crank
File Type: jpg
File Type: jpg
Old 04-27-2014, 12:43 PM
Swiley383
Swiley383's Avatar
What do you guys think should I open up the wallet and go back solid roller or stick with a solid flat tapped. I would like to run 6.90- 7.00 1/8 mi range. I have good heads a 12.6 to compression the motor never ran what I felt it should. I have been going back and forth on this I am driving my wife crazy trying to decide.
Old 04-27-2014, 12:48 PM
  #18
MEMRACING62
Kinda hard to see crank surface....hope she's alright....lost a block and crank due to spun bearing due to a past owner using Teflon tape to install a oil pressure sending unit....oil hole plugged with tape in block.
MEMRACING62 is offline
