My frist drag car build up
Old 11-12-2008, 08:55 PM
  #21
Default Re: thanks guys
Originally Posted by bigblock888
I was told that this rocket was bored and stroked .whats the max cubs in I can get out of it? :?: :?: :?:
You can probably only get 2 cubs out of it and generally speaking one will be female and the other will be a male. Now if you want to go back to engines, .060 is the safest you can bore it.
Old 11-13-2008, 01:21 PM
  #22
olds48
:lol: :lol: :lol: :shock: ops:
olds48 is offline
Old 11-19-2008, 04:29 PM
  #23
bigblock888
Default how about the rear end
accordind to the numbers I got it,s an 8.5 10 bolt how strong is it and how much power can I put to it with small slicks with out twisting an axle
bigblock888 is offline
Old 11-28-2008, 06:02 AM
  #24
mopar1962
JUNIOR BUILDER
regardless of the engine brand you use concentrate on a stout bottom end even if you are going to run a slower class. doing this means you can always upgrade in the future and not have to worry about handling the power. cant beat chevy prices on engines, cost to hp ratio
mopar1962 is offline
