TIMING ? AGAIN
Old 08-14-2009, 04:16 AM
  #21
JEFF69Z28
Originally Posted by Tod74
Originally Posted by JEFF69Z28
Originally Posted by cepx111
I'd re-gap the plugs to no wider than .032 and try again.
JMO>Cp
I THOUGHT OF THAT,BUT MSD SAID 45 TO 50,WHAT WOULD BE THE REASON OF A SMALLER GAP?
High cylinder pressure can "blow out" the spark if the gap is too large....maybe a poor way of wording it.
WHAT CAUSES HIGH CYLINDER PRESSURE?
JEFF69Z28 is offline
Old 08-14-2009, 04:36 AM
  #22
wmeabates
Jeff,Did you set your timing pointer to your damper using a piston stop? Bill.
wmeabates is offline
Old 08-14-2009, 04:49 AM
  #23
JEFF69Z28
I did not build the engine,thats something else i read about to see if the timing mark is in the correct spot..how can i do that now that the enginge is together,is there a piston stop that can be inserted in a plug hole.
Old 08-14-2009, 06:35 AM
  #24
desoto30
JUNIOR BUILDER
Not that I know of But I made one by cutting the guts out of a spark plug & welding a piece of steel in that protruded into the cylinder area thereby not allowing the engine to rotate past the bit sticking in. Obviously you will need to be able to turn the engine over gently so as not to bend it.
desoto30 is offline
Old 08-14-2009, 06:47 AM
  #25
wmeabates
Yes someone makes a stop that goes in the plug hole.Remove all the spark plugs and it will be easyer to feel the piston hit the stop.Bill.
Old 08-15-2009, 10:14 AM
  #26
desoto30
JUNIOR BUILDER
& if the engine has any sort of big valve springs I would also back them off also
desoto30 is offline
Old 08-15-2009, 01:23 PM
  #27
Tod74
JMO>Cp
Higher compression, Nitrous, turbo, blower, cam timing....whatever. That's the whole point. The more air you can pump through the engine the more power it will make..think of an engine as a big air compressor. An engine with 12 to 1 compression has 12 times the amount of air in the cylinder at BDC as it does at TDC..The more air you get into the cylinder on the intake stroke the more cylinder pressure you will have when it's compressed, therefore more power on the power stroke. Again, maybe poor wording because valve timing effects the cylinder pressure too but that's pretty much how I think of it.
Tod74 is offline
Old 08-15-2009, 02:28 PM
  #28
DirkaDirka
DirkaDirka's Avatar
Ok what are things you can do to achieve higher compression ratio??
DirkaDirka is offline
Old 08-16-2009, 06:48 AM
  #29
markdunlap
Default TIMING?AGAIN
You can use a threaded positive stop in the spark plug hole to find true TDC. BUT BEFORE YOU USE IT, take the rockers off that cylinder or you can bend the valves.
If your balancer is marked in degrees before TDC, screw the positive stop in to stop at 30 degrees. Then measure carefully the distance from zero to 30 degrees and put a mark on the other side of zero at that measurement. Rotate the engine backward slowly till it is against the the positive stop again. If it stops at 30 degrees, your timing pointer is correct. If not, move the pointer until it is equal degrees on both sides of the positive stop.
If you only have a zero mark on your pointer, just pick any measurement around 1 inch and put that on both sides of your zero mark and move your pointer until the measurement is equal on both sides of mark.
Morroso, Manley, MR Gasket, Comp Cams and others make an aluminum threaded positive stop.
markdunlap is offline
Old 08-17-2009, 01:34 AM
  #30
JEFF69Z28
WHEN THE #1 PISTON WAS AT TDC THE ROTOR IS POINTING AT THE NUMBER 6 CYLINDER AND THE #1 PLUG WIRE IS IN THAT AREA ON THE CAP SHOULD I PUT MY TIMING LIGHT ON THAT WIRE?OR SHOULD I TAKE THE DIST.OUT AND HAVE THE ROTOR POINTING AT NUMBER ONE.BOY AM I CONFUSED!
