biulding 388 sbc
Old 10-31-2010, 04:04 PM
  #21
greenone60
JOURNEYMAN
Originally Posted by spib
Originally Posted by maxpower671
Originally Posted by greenone60
i have a 388 sbc with ik200 brodix heads and solid roller cam and 13.1 comp and it made 600 hp at the flywheel.hopes this helps
please discuss... :wink:
my motor is like guy aboves, 385
010 block, block filled to water pump,13.2to1 compression
all 4340 rotating stuff
210 cnc afr heads, T&d shaft rockers
crower custom built for my motor 4/7,2/3 swap cam, big roller
super victor intake, pro system 4150 carb
Its over 600, and it runs
here are some specs. comp cam part #12-773-8 it is the xr292r cam with spilt duration intake 292 ex 297 intake lift 582 ex 588 and its on 107 center lobe iam running 1.6 rockers,ik200 heads with 200cc runners out of the box,victor jr intake port match to heads,eagle 4340 rotating assy with 6inch h-beam rods,13.1 je pistons,850 quick fuel carb,its in a 79 malibu w/driver 3200 and manily a 7.0 heads up car,best its been on motor is 6.88 1/8 mile
greenone60 is offline
Old 11-03-2010, 08:46 PM
  #22
maxpower671
SENIOR BUILDER
very nice!.....thanks for sharing 8)
maxpower671 is offline
Old 11-04-2010, 08:45 AM
  #23
hvychvy
JOURNEYMAN
Brodix IK200, about the best bang for your buck. I'm in the same situation as you with kids budget and all,I got those heads on my 383 with KB pistons and from my time slips the hp with a small cam is right there where you want to be.
hvychvy is offline
Old 11-06-2010, 04:58 PM
  #24
jaxsmith
How bout 6 kids on a tight budget.
388 eagle assembly with 5.7 rods and KB134 flat tops
AFR 220X old heads milled to 48 cc chambers
Roller cam (drag race only) alky inj toilet
Powerglide
2950lb car 6.29 @ 108 1/8 1.29 60 ft
Zip put it together and Zip and some more on here have seen it run.
Leave on the converter (5800) and it will ride the bumper for 300+ft
Go with what you have. You can find a good set of aluminum heads for around 900 used. Then you have 600 to spend on that intake and carb. Buy a Holley Blue and have fun.
jaxsmith is offline
Old 11-08-2010, 08:15 AM
  #25
rapedape
APPRENTICE
I found a set of RHS alumiun heads for sale used The guy only want $800 but i havent been able to cross reference any of the numbers on the heads. He says they have 2.02 valves but he didnt know the runner sizes. Plus I think they have had some work done to them. He says "they flow like crazy " but he can't produce any numbers or any info about them. Are RHs heads any good or will can I expect the results I'm looking for from these heads ?
rapedape is offline
Old 11-08-2010, 10:23 AM
  #26
Have you tried calling RHS to check the #'s ? they might be a good and they might not. The smaller runner heads don't flow much according to their own flow charts, how ever the 235 runners flow up to 315 CFM. A good running 383 will need 300 CFM or more to perform at it's best. i've heard those words before they flow like crazy, but unless you can get some actual flow #'s i'd be careful of the purchase.
