Oil pressure
Old 12-28-2009, 01:18 PM
  #41
BEAST477
BEAST477's Avatar
Glad you found the problem. Now you can sleep better at night and stop pullin' your hair out. At least the hair you have left. :shock: :lol:
BEAST477 is offline
Old 12-28-2009, 01:34 PM
  #42
THERATTLER
THERATTLER's Avatar
I knew it had to be leaking somewhere , too bad you can't drill it , tap it and plug it...glad you found it,
THERATTLER is offline
Old 12-28-2009, 06:48 PM
  #43
TheYellaBrick
TheYellaBrick's Avatar
The next question is;... what caused it to crack at that location ?
or was it a casting flaw ?
TheYellaBrick is offline
Old 12-28-2009, 07:30 PM
  #44
mopar1968
mopar1968's Avatar
Yes it is a casting flaw, when new bearings, gaskets were installed, everything sealed tight where oil pressure was up for a few minutes i guess it finally blew out and started leaking, could have been seeping all along :!: :!: Have new block building now :!:
''JUST MY TWO CENT'S WORTH''
mopar1968 is offline
Old 01-02-2010, 08:17 PM
  #45
mopar1968
mopar1968's Avatar
Got new engine together, 60 psi @ cold idle, 38 psi hot idle. 205 degrees.
