need help to find the right street-strip 572 cam
Old 11-17-2007, 02:15 AM
russ67chevelle
main goal is to make most power(torque)possible to obtain most horsepower within the 7000 rpm peak i wanna push motor.if my peak hp number is at 6500-6700 rpm then shifting by 7000 should establish goal.........which my question still is unanswered...........what should be best duration for peak hp at 6500-6700 rpm?
russ67chevelle is offline
Old 11-18-2007, 05:03 AM
blue66
APPRENTICE
There is just more to it than a duration #.
Cam profiles at .050, is one measurement point of the whole lobe.
Lets say someone answers your question and says 276* @ 050. There's hundreds of different lobe designs with that degree @ .050. But what about at .006, .100, .200, .300,.400 etc etc. This will all factor in. If you want a cam that will work with your particluar combo, you will need to talk with a few reputable cam companies. And not the yahoos' @ the cam help line at comp. Unless you can get a real cam tech on the phone. Maybe try calling a few and see what they say.
Bullet cams, Cammotion, Reed Cams, Camdynamics.
On your Chevelles site post. UDHarold that posted a reply to your thread is one of the best in the business also.
He designed the Ultradyne Cams that Bullet is now using a lot of,
Worked for Lunati and designed the VooDoo series.
Worked for CustomCamshaftCo. and came up with some more stuff.
What was the 60ft on your pass. 572 inches should pull pretty hard even overcammed and understalled I would think?
blue66 is offline
Old 11-18-2007, 10:54 AM
russ67chevelle
it was 90 degrees when i ran.60 ft. was 1.568.330 was 4.294.1/8th mi was [email protected] was 8.326.1/4 was [email protected].
Old 11-26-2007, 06:03 PM
russ67chevelle
is there anyone here thats dynoed their big cubic inch motor?any other cam gurus have any proven formulas for big torque and hp on 93 juice?its winter so im gathering as much info as possible....
Old 11-26-2007, 09:34 PM
cepx111
HUH?
cepx111 is offline
