12 BOLT OLDS REAREND WITH 12 BOLTS ON RING GEAR...HELP!!!!!!
Old 08-17-2008, 03:45 PM
gungho
where have you seen a olds 12 bolt ring gear rearend?this is not a chevy 12 bolt I have 2 chevy 12 bolts here,and it is nothing like it,my question is has anyone seen this or have any pics or know the application I bought it to put under my 72 chevelle but found out the chevy diff cover dont fit
gungho is offline
Old 08-17-2008, 04:22 PM
Tod74
MEASURE THE RING GEAR ..then it will be easier to find out what it came out of.
Tod74 is offline
Old 08-17-2008, 07:20 PM
mytmouz
mytmouz's Avatar
Sounds like a Dana 44, but the cover on those for the BOP's is usually a 10 bolt...
mytmouz is offline
Old 08-18-2008, 03:47 AM
Tod74
they had them with 12 bolts too but the cover is smooth and round like a 10 bolt .
Tod74 is offline
Old 11-13-2008, 02:38 AM
JEFF69Z28
12 BOLT IS HOW MANY RING BOLTS THE RING GEAR HAS NOT SO MUCH HOW MANY COVER BOLTS.
JEFF69Z28 is offline
Old 11-30-2008, 10:08 AM
kaz442
Canandain built oldsmobiles had 12 bolt chevys. JKaz
kaz442 is offline
Old 12-03-2008, 01:58 PM
monzaz
Default 12 bolt olds rear
You have a full size 12 bolt olds rear diff. 1967-1970ish deltas 88 98 had a 12 bolt FULL size 'O' type 12 bolt rear. This rear came with 12 bolt symmetrical cover and 12 bolt ring gear .
The 12 bolt mid size or A-body GM 'O' 12 bolt with a symmetrical cover has 12 bolts on the cover and 10 bolts on the ring gear. These were in the olds cutlas, 442 AMERICAN made cars only 1967 -1970. Canadian car received the 12 bolt chevy rear and was open non posi diff.
then in 1971 1972 the rear was a 10 bolt 8.5 corperate just like the all the 70's and 80's cars and 1/2 ton trucks...ONLY they came wioth bolt in axles.
1973 was the switch to a new body style so that rear will not bolt into the 1972 and older body style.
So I am sure you have a FULL size 12 bolt 'O' type rear in your hands there. If I had pictures of the housing cover and or posi unit I could ID it for sure. Jim
monzaz is offline
Old 12-20-2008, 05:02 AM
  #18
gungho
gungho is offline
Old 12-20-2008, 10:16 AM
  #19
Tod74
That is the exact same rearend I had that I mentioned previously...right down to the "S" spring in the carier. mine had 10 bolts in the ring gear and the axles from a 12 bolt chevy did not fit.
Tod74 is offline
Old 12-20-2008, 11:23 AM
  #20
gungho
Yes, but this ring gear has 12 bolts.
gungho is offline
