How long does alcohol last
Hey Chris,
We started using Klotz top end lube and we really like it alot. We actually picked up some et using it over whatever they were putting in when we bought our fuel with the lube already in it. David is right it will keep just fine.
Curtis
Curtis
Hey Chris,
Curtis
Curtis
Chris
Don't worry as fast as you burn alcohol it wont last long. Usually when someone gets a new alcohol engine theyll burn a drum just tuning their car in the shop.
If you'll install a 3/8 fitting on the plenum of your intake and run a hose back to the cab of your car with a gas ball valve on your end. You can heat up your engine in about 1/3 the time. When you open the valve it will give you a vacuum leak that will lean your engine. It will heat up aleast 3 times faster. Which means you use 3 times less fuel.
Hey Chris,
Curtis
Curtis
Chris
Originally Posted by fla1976
Chris
#19
I have another question. Since my car runs on alcohol, could I run E-85 in it? Again sorry for all the questions but first time with an alcohol setup.
Chris
Chris
Curtis
#20
Chris
Chris
Curtis
I see now, I have a lot to learn.............. :? :?
Chris
