Fram oil filter
Old 04-24-2009, 06:39 PM
kwkracing
Is it a racing fram filter? Designed for high oil pressure?
I think motors tear up and destroy filters
kwkracing is offline
Old 04-24-2009, 07:26 PM
THERATTLER
THERATTLER's Avatar
I had a fram on a sbc with the bypass plugged in a dragster , made 2 passes on fresh oil and filter , lost pressure while on return road , shut it off and pulled it back to truck , I thought the worst and a friend of mine said to check the filter , we did and it was collapsed. :shock: ..borrowed a wix from another racer and fired it back up , full pressure , have been useing wix or napa (same filter) ever since with never a problem ,
THERATTLER is offline
Old 04-24-2009, 09:58 PM
cepx111
OH boy more aweful stories abou t fram oil filters killing motors.
I thought ever one knew they were motor killers by now.
Maybe we need a sticky on this one.
*BEWARE!!!!! DO NOT USE A FRAM OIL FILTER ON YOUR MOTOR*
cepx111 is offline
Old 05-22-2009, 05:16 AM
JEFF69Z28
WHAT ABOUT AC DELCO FILTERS?
JEFF69Z28 is offline
Old 05-22-2009, 03:44 PM
Scooterz
Originally Posted by tcarda
I have never used them either because of stories like this too. :!:
Has anyone used or use the K&N oil filters?
JimmySmith, how is the motor in the car or did it do any damage?
Tcarda: I use the K&N (HP3100? I think). anyways, last 2 oil changes have been fine & I use a single remote system. Good Luck. Scooter
Scooterz is offline
Old 05-22-2009, 04:21 PM
hammertime
purlator pure ones .. best I've used so far. cut them open you'll be able to tell whats the best
hammertime is offline
Old 05-22-2009, 06:39 PM
jmarksdragster
jmarksdragster's Avatar
Here is some reading on filters.
http://minimopar.knizefamily.net/oil...reference.html
http://minimopar.knizefamily.net/oil.../opinions.html
jmarksdragster is offline
Old 05-25-2009, 07:56 PM
  #18
MEMRACING62
2006 CHEVY TRAILBLAZER ENGINE ALMOST TAKEN OUT BY BAD PENNZOIL FILTER. STOCK ENGINE , 5W 30 OIL . ABOUT 2000 MILES INTO OIL CHANGE. FRAM MAKES PENNZOIL FILTERS.
MEMRACING62 is offline
Old 06-04-2009, 07:57 AM
  #19
PacoMorales
I run Fram filter on an Aluminum sprint car SBC. BUT filter is HP4 ir HP1 Fram filter would'nt think of puting a stock filter on as I have 80 lbs pressure. never any bad luck with those.
PacoMorales is offline
Old 07-06-2009, 05:03 PM
  #20
newjack42
JUNIOR BUILDER
a guy i work with lost a mild 427 in his street car to a fram. roded on her a bit filter collapesed and he didnt notice the press. drop and torched the motor. nothing but wix in the truck and wix racing filter in the dirt mod. never had a problem.
newjack42 is offline
